EcoFlow DELTA 2 Max Solar Generator Extra Battery | EcoFlow NG – EcoFlow Nigeria
EcoFlow Nigeria
₦1,019,000.00 NGN
Secure Payments
Multi-channel Support
Regular price ₦1,019,000.00 NGN
Sale price ₦1,019,000.00 NGN Regular price ₦1,341,199.00
Save ₦322,199.00
*Important: This is an Extra Battery. It cannot be used alone and must be connected to a compatible power station.
• Expandable capacity - Increase the capacity of DELTA 2 Max with an extra 2048Wh.
Triple the power - 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 6144Wh. Ideal for home backup, caravanning, outdoors or even everyday use.
• Built to last 6× longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000 cycles.
• 5-Year Warranty
Accessories
₦1,019,000 NGN ₦1,341,199 -₦322,199
Secure Payments
Take Capacity to the Max
With an expandable design, triple the capacity from 2kWh to 6kWh.
Power your essentials like your fridge for up to 42 hours¹
¹Data based on 6kWh capacity running a 120W referigerator.
2048Wh
Input Port
51.2V, 2000W Max
Output Port
51.2V, 3200W Max
Battery
LFP chemistry, 3000 cycles to >80% capacity
Dimension
464 × 235 × 283 mm (18 × 9 × 11 in.)
Weight
19kg(42lbs)
What’s in the box
EcoFlow DELTA 2 Max Smart Extra Battery, Extra Battery Cable, User Manual, Warranty Card
Compatible with
DELTA 2 / DELTA Max 2000/ DELTA 2 Max
Online 24 hours
