EcoFlow DELTA 2 + EcoFlow DELTA 2 Smart Extra Battery – EcoFlow Nigeria
EcoFlow Nigeria
₦1,087,273.00 NGN
Regular price ₦1,087,273.00 NGN
Sale price ₦1,087,273.00 NGN Regular price ₦1,570,378.00
Save ₦483,105.00
  • Expandable capacity - 1-3kWh expandable capacity to grow your storage to your needs. Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
  • Huge AC output - 1800W AC output means you can power more than 90% of your home appliances. Or, try plugging in up to 15 devices at once. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology.
  • 7x Faster AC charging - X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That’s 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input.
  • Or go green without sacrificing speed - Plug in portable solar panels and get up to 500W input to charge from anywhere in as fast as 3 hours.
  • Built to last 6x longer - Get years of regular use until hitting 80% capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
  • Control from anywhere - Use the EcoFlow app to control your DELTA 2 from anywhere using Wi-Fi. Link with Bluetooth when off-grid. Either way, you can check charging data, customize settings and adjust the charging speed with ease.
    ₦1,087,273 NGN ₦1,570,378 -₦483,105
    EcoFlow DELTA 2 is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
    Expand capacity.
    With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh. Great for home backup or everyday appliances.
    Power pretty much anything.
    A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
    Go green without sacrificing speed.
    Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
    Pick from a range of solar panels to get the speed you need (110W, 160W, 220W, 400W). With that, you've got access to free energy anywhere.
    Built to last 6x longer.
    Finally… tech that's made to last. Get years of regular use until hitting 80% of its original capacity. That's down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
    Safety first
    DELTA 2's built-in battery management system regulates vitals to keep it safe, secure, and built to stand the test of time.
    Ready for emergencies.
    Control from anywhere.
    1.DELTA 2 2.AC charging cable 3.Car charging cable 4.DC5521 to DC5525 cable 5.User manual 6.App quick start guide 7.Warranty card
    1024 Wh
    Extra Battery
    4 outlets, 1800W total (Surge 2700W)
    2400W
    2 ports, 5V, 2.4A, 12W Max
    USB-A Fast Charge
    Car Power Output
    1 port, 12.6V, 10A, 126W Max
    DC5521 Output
    2 ports, 12.6V, 3A, 38W Max
    AC Charging
    1200W
    11-60V, 15A, 500W max
    Car Charging
    Support 12V/24V battery, 8A
    DC Charging
    1100W
    LFP (LiFePO4 battery)
    Cycle life
    3000 cycles to 80+% capacity
    Connectivity
    Wi-Fi & Bluetooth
    27 lbs / 12 kg
    * Source:
    Online 24 hours
