EcoFlow Nigeria
EcoFlow DELTA 3 Air Series Portable Power Station
Regular price ₦941,000.00 NGN
Sale price ₦941,000.00 NGN Regular price ₦1,219,679.00
Save up to ₦450,528.00
  • Up to 1000W Rated Output
  • Up to 1920Wh All-Day Power
  • Compact, Lightweight, Portable
  • Zero Emissions—No Fumes, Fuel, or Mess
  • 3 Fast Charging Options in 2 Hours
  • Fire-Resistant (UL94V-0) & Anti-Vibration Structure
  • 10-Year Lifespan with LiFePO₄ Battery
₦941,000 NGN ₦1,219,679 -₦278,679
₦941,000.00 NGN
Why it Matters for Your Family
Go Solar, Save Million
No fuel, No Noise, No Blackout
Choosing solar means clean, reliable power that cuts fuel costs to zero, keeps your space quiet, and delivers worry-free energy anytime you need it.
Powers 99% Home-Essential Appliances
DELTA 3 Air delivers reliable power for nearly everything your family needs—from fans and lights to TVs and refrigerators. And with X-Boost mode, it can handle higher-wattage appliances too, so even cooking with a rice cooker is worry-free.
DELTA 3 1000 Air
DELTA 3 2000 Air
Power That Lasts All Day
With its high-capacity design, the DELTA 3 Air series delivers long-lasting backup for your home essentials. From keeping a light on through the night to running fans and refrigerators during extended outages, it gives your family all-day peace of mind without interruption.
Home Essentials
Home Office
Outdoor
Get Ready in 2 Hours
With EcoFlow’s X-Stream fast AC charging, DELTA 3 Air fully recharges in just 2 hours—ready before the next outage. For flexibility, you can also top up with up to 1000W of solar, or recharge via generator or car when off-grid.
0 Maintenance. 0 Installation.
Say goodbye to upkeep and complicated wiring. With an all-in-one design that combines battery and inverter, DELTA 3 Air works just like a big power bank—unbox, plug in, and power your home essentials instantly.
Compact Design, Fits in Every Corner
Roughly the size of a rice cooker, the DELTA 3 1000 Air weighs just 9.9kg and features a built-in handle—making it easy to move around the house or take wherever you need reliable backup power.
₦489,000
₦739,199
Dimension: 220 × 223 × 263 mm
Net Weight: 9.9kg
₦489,000
₦739,199
Built to Last for
10 Years
With all-around protection inside and out, the DELTA 3 Air series is engineered for long-term reliability.
UP to 6,439 kWh
DELTA 3 Air series can deliver up to 6,439 kWh,over its lifetime—safe, dependable power for your family, year after year.
Strong Outside
A fire-resistant shell (UL94V-0), shock-absorbing CTC structure, and corrosion protection against oil, salt spray, and humidity keep DELTA 3 Air durable for longer, safer use in any environment.
Safe Inside
Smart BMS technology delivers 24/7 monitoring with seven layers of protection, while long-lasting LFP (LiFePO₄) cells operate safely from –20°C to 60°C—ensuring reliable power and extended battery life.
Strong Outside
Safe Inside
Instant Protection, Real-Time Control
Uninterrupted Power Supply (UPS)
With a switchover speed as fast as 10ms, DELTA 3 Air instantly takes over when the grid goes down. Your lights stay on, your work continues, and your family’s essentials remain powered—without a single interruption.
Smart App Control
Smart App Control
Track real-time energy use and battery status directly from your phone. See exactly how much power your essentials consume, get instant alerts when issues occur, and customize charging speeds, schedules, and alerts—all with a tap.
Smart App Control
Smart App Control
Explore the DELTA 3 Air Series
EcoFlow DELTA 3 1000 Air
EcoFlow DELTA 3 2000 Air
Home Essentials Power
High-Capacity Power Station
Essential, Compact, Affordable Backup
Advanced, High-Power, Premium Backup
₦489,000
User Manual
₦941,000
User Manual
960Wh
Rated Capacity
1920Wh
Rated Capacity
500W
X-Boost 1000W
AC Discharging Power
1000W
X-Boost 1500W
9.9kg
17.8kg
220*223*263 mm
8.7*8.8*10.4 in
Dimensions (HWD)
220*223*426 mm
8.11*4.53*4.84 in
Dimensions (HWD)
<10ms
UPS
<10ms
UPS
500W
AC Charging
1000W
AC Charging
500W
500W*2; 1000W Max
500W
AC
1000W
AC
1*12W, 12Max
USB-A
2*12W, 24W Max
USB-A
1*18W, 18Max
USB-C
2*18W, 36WMax
USB-C
LFP (LiFePO4)
Cell Chemistry
LFP(LiFePO4)
Cell Chemistry
2 years
Warrenty
2 years
Warrenty
YES
App Remote Control
YES
App Remote Control
Appliance Runtime
₦489,000
User Manual
₦941,000
User Manual
43 hours
Wi-Fi Router
80 hours
Wi-Fi Router
41.5 hours
Light
73 hours
Light
20 hours
Fan
24 hours
Fan
42 times
Phone
80 times
Phone
15 times
Laptop
27 times
Laptop
8 hours
TV
14 hours
TV
20 hours
Refrigerator
40 hours
Refrigerator
8 hours
PC
15 hours
PC
1.5 hours
Coffee Maker
2.5 hours
Coffee Maker
1 hour
Rice Cooker
1.8 hours
Rice Cooker
1. EcoFlow is the No. 1 portable power station brand in the world based on sales and revenue in 2024. Data source: Frost & Sullivan "2024 Global Portable Energy Storage Market Report."
2. Research completed in April 2025. Portable power stations are small energy storage devices with built-in lithium-ion batteries with a capacity of 100Wh-3000Wh.
3. Runtime is based on powering a single appliance. All test results shown are based on internal testing and may vary depending on usage conditions.
4. Noise levels are measured at a distance of 1 meter under standard lab conditions. DELTA 3 1000 Air operates below 39 dB; DELTA 3 2000 Air operates below 44 dB.
5. All lifespan-related data is based on EcoFlow’s internal laboratory tests. Results may vary depending on actual usage conditions such as temperature, humidity, and equipment settings. These figures are for reference only and do not guarantee the same outcome in all scenarios.
6. Tested under controlled laboratory conditions: DELTA 3 2000 Air delivers up to 6,439.68 kWh accumulated over 10 years, while DELTA 3 1000 Air delivers up to 3,219.84 kWh.
7. UPS performance varies by model: DELTA 3 1000 Air = 20ms, DELTA 3 1000 Air (10ms UPS) = 10ms, DELTA 3 2000 Air = 10ms.
Online 24 hours
