EcoFlow Nigeria
EcoFlow 60W Portable Solar Panel
₦91,000.00 NGN
Regular price ₦91,000.00 NGN
Sale price ₦91,000.00 NGN Regular price ₦158,000.00
Save ₦670.00
  • Up to 25% conversion rate
  • Laptop-size when folded, easily fits into small spaces
  • IP68 rating protects against water and dust
  • Designed for hanging on vehicles, tents or backpacks
  • Ideal solar power source for RIVER 3 and RIVER 2 Series
  • DC5521 to XT60i charging cable is included
También te puede interesar
₦91,000 NGN ₦158,000 -₦67,000
Fast and efficient solar charging.
With a high 23.4% conversion rate, the RIVER 2 portable power station can be fully charged in just 5 hours during peak sunlight hours. This means you can charge RIVER 2 anywhere and keep your essential appliances powered up.
Take solar power on the go.
EcoFlow's RIVER 2 Solar Generator is a must-have for camping or RV trips. Our new 60W portable solar panel is the lightest and most convenient option available. With a weight of only 3.2kg and a folding design, it's easy to grab and go at any time.
Power up in a flash with a 10-second setup.
Our brand-new foldable solar panel design allows for easy setup, so you can start harnessing the sun's energy right away. Plus, with a flexible angle adjustment from -30° to 60°, you can optimize your charging angle for maximum efficiency.
Built to weather the storm.
Our 60W portable solar panel is built to withstand a range of environments, from humid and wet to dry and dusty. With a high IP68 waterproof rating and a protective ETFE film, the solar cells continue to collect energy even during downpours.
Compatible with virtually all power stations.
Our solar panels use an all-inclusive connector that easily pairs with all EcoFlow power stations and most third-party batteries on the market, providing a convenient and seamless charging experience.
Take control with the Ecoflow app.
60W Portable Solar Panel is compatible with the Ecoflow app when connected to an EcoFlow power station. Monitor your solar charging status with smart, easy, and customized app control in real-time.
Unleash the Sun's Power for all Your Outdoor Adventures
Solar to XT60i Charging Cable
60W Portable Solar Panel Bag
User Manual and Warranty Card
Rated Power
60W
Efficiency
23.4%
Short Circuit Current
3.5A
Open Circuit Voltage
24.5V
Cell Type
Monocrystalline silicon
Connector Type
Solar connector
Dimensions (folded)
38*40.2*2.5cm
Dimensions (unfolded)
103*40.2*2.5cm
Weight (with kickstand case)
3.2kg
Online 24 hours
