EcoFlow Nigeria
₦2,748,980.00 NGN
Hot
Hot
Regular price ₦2,748,980.00 NGN
Sale price ₦2,748,980.00 NGN Regular price ₦3,738,558.00
Save up to ₦1,251,658.00
• Recharge your RV and EV anytime, anywhere
₦1,882,000 NGN ₦2,561,999 NGN
Compatible with DELTA Pro
₦2,748,980 NGN ₦3,738,558 -₦989,578
Power for any situation.
All the AC output you’ll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W.
Smart home battery ecosystem.
DELTA Pro's expandable ecosystem provides you with uninterrupted power during blackouts, customizable smart energy around the clock for critical loads, and lower energy bills.
Smart energy management.
Control each of your integrated home circuits via the EcoFlow app and get a birds-eye view of your energy consumption habits. Dive into the settings to customize your power use. You can optimize for home backup, saving money, or custom options to schedule your energy use based on your needs. Once you're set, you can even control which power source your house uses, all from your phone.
Draw power from your DELTA Pro(s) to power your home during peak energy use hours, this lowers your bills and reduces pressure on the grid during peak hours. During off-peak hours, use low-cost/renewable energy to charge your DELTA Pro(s) back to full.
Reduce your reliance on the grid and prepare for blackouts. Opt for EcoFlow's range of portable solar panels to store energy at any time, or charge from your AC coupled rooftop solar panels while the grid is on-line. No sun? We're working on a wind turbine. No sun or wind? Charge via the grid. No sun, no wind, and a blackout hits? You're still good. Lean on the EcoFlow Smart Generator as a last resort to charge your batteries.
Power that means business.
Unleash your creativity.
Take energy on the go and get the creative juices flowing. Whether you're a filmmaker capturing precious moments or just want to work on the go, DELTA Pro's impressive output and large capacity can power all your equipment, ensuring a smooth workflow no matter where you are.
1. DELTA Pro 2. AC Charging Cable 3. Car Charging Cable 4. DC5521 to DC5525 cable 5. Handle Cover 6. User Manual
*EcoFlow DELTA Pro to Smart Generator Adapter (sold separately) is necessary when the DELTA Pro is connected to the Smart Generator.
Approx. 45kg
Dimension
3600Wh
Extra Battery
4500W
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
2900W Max, 230V~12.5A
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth
What's the max input DELTA Pro can achieve?
When charging DELTA Pro and its extra battery together, you can reach 6500W max charging speeds by combining AC, solar and Smart Generator methods. For DELTA Pro single unit, you can recharge it at standard wall outlets (2900W max), at EV station (3400W max)/Smart Home Panel (3000W max).
How many solar panels can I use at the same time?
It depends on the combined voltage and current of the solar panels you choose. It's fine as long as the solar panels use solar connectors and their combined voltage and current are within 11-150 volts and under 15 amps.
How do I update the firmware?
First of all, make sure your DELTA Pro is connected to the EcoFlow App using Internet mode. Secondly, go to the Firmware section in the Setting of the DELTA Pro you're looking to upgrade. Check for the latest firmware and follow the steps to finish the upgrade.
Online 24 hours
