EcoFlow Nigeria
₦450,080.00 NGN
Hot
Hot
Regular price ₦450,080.00 NGN
Sale price ₦450,080.00 NGN Regular price ₦790,578.00
Save up to ₦626,298.00
  • RIVER 3 Plus: 286Wh capacity; RIVER 3 Max: 572Wh capacity; RIVER 3 Max Plus: 858Wh capacity.
  • 600W rated output and 1200W X-Boost.
  • 1-hr fast charging, no battery damage.
  • Up to 220W fast solar charging.
  • Up to 2× runtime for light-wattage appliances.
  • Compact and lightweight.
  • <10 ms pro-grade UPS for precision devices.
  • <30 dB whisper quiet for 24/7 use.
Power Station
Accessories
₦450,080 NGN ₦790,578 -₦340,498
Your reliable companion through outages or on the go
Expandable up to 858Wh with wireless connectivity
Level up your power with the RIVER 3 Plus and an Extra Battery. Handling either the EB300 (286Wh) or the EB600 (572Wh), just stack them to get up to 858Wh of pure energy.
286Wh
572Wh
858Wh
Hassle-free connection
Utilising pogo pin tech, the batteries connect wirelessly, fastening easily with clips instead of cables or screws.
Adds an extra charging and
recharging option
Add an extra battery to your RIVER 3 Plus for 140W USB-C charging and recharging, plus the freedom to use it on its own.
Capable of running 90% of home appliances
Up to 600W output
RIVER 3 Plus is a beast in the small power station game, cranking out up to 600W of rated power. Its X-Boost technology can continuously handle 1200W heating devices without breaking a sweat, keeping 90% of home appliances running smoothly. With an additional built-in light, you'll never get left in the dark.
4 charging options, safely charge 0-100% in 1 hr
0-100% in 1.5 hr
0-100% in 1 hr
0-100% in 3.3 hr
0-100% in 1 hr
Solar Charging: Power up RIVER 3 Plus in as fast as 1.5 hours with 220W solar input. Go more portable with our 45W Portable Solar Panel (Type-C) and charge electronics directly.
AC Charging: RIVER 3 Plus fast-charges in 1 hour with X-Stream, without causing battery damage due to vehicle-grade cells and trickle charge technology.
Car Charging: Charge RIVER 3 Plus using your car battery while you drive, making it an ideal choice for on-the-go.
Generator Charging: Recharge in just 1 hour with a gas generator for a full day of quiet, safe, and efficient power.
<10 ms pro-grade auto-switch
Seamless home office and gaming experience
The RIVER 3 Plus provides premium protection with a <10 ms switchover, safeguarding sensitive equipment for home office and gaming experiences against sudden power loss.
Comprehensive UPS solution
Safeguards for work and play
Equipped with a 286Wh capacity and 600W output, RIVER 3 Plus can power a 3W Wi-Fi router for up to 35 hours. Plus, it can run pretty much any office appliance, including 600W computers, for at least 21 minutes, allowing for a safe shutdown and completion of ongoing tasks.
Smart outage alert
Stay alert during power outages with the RIVER 3 Plus, equipped with an LED, app, and software alerts. Its PC and NAS-compatible data interface, along with the EcoFlow software, notifies you and automatically saves data when the battery is low.
UPS-friendly design
With two rear AC outlets, conceal your device cables. Plus, monitor UPS in real time on the upgraded screen.
Up to 2× light and network runtime
Easily handle power outages and extend outdoor stays
Leveraging GaN's superior energy efficiency, the RIVER 3 Plus revolutionises the industry with compact, quiet batteries, delivering up to twice the operating time for light-wattage appliances.
Extremely compact and lightweight
Handy, convenient on-the-go power
It easily fits into small spaces like closets, minivans, or bags for convenient storage.
< 30 db whisper quiet for 24/7 backup
Quiet backup for peace day and night
With heat-dissipating X-GanPower technology, RIVER 3 Plus operates on a library-like silence level, with a volume of less than 30 dB at a distance of 0.5 m. You'll have peace day and night guaranteed, even when it's running nonstop.
With IP54 battery protection, water damage is minimised. Its robust fire-retardant shell survives rough conditions. Even after a 1-metre fall, RIVER 3 Plus won't get damaged.
RIVER 3 Plus has a lifespan of 3000 charging cycles. That's around 10 years of everyday use before its capacity drops to 80%.
Featuring an advanced algorithm for cloud-based battery monitoring with 40+ safety measures, RIVER 3 Plus protects against various current, voltage, temperature, and circuit risks.
Upgraded smart control
Convenient, intelligent, customised power control
Product Details
RIVER 3 Plus
RIVER 3 Max
RIVER 3 Max Plus
Specs - RIVER 3 Plus Series
RIVER 3 Plus: 286Wh
RIVER 3 Max: 572Wh
RIVER 3 Plus: 234 × 232 × 146 mm
RIVER 3 Plus: 4.7 kg
RIVER 3 Plus Extra Battery Dimensions
EB300: 234 × 224 × 110 mm
EB600: 234 × 224 × 158 mm
RIVER 3 Plus Extra Battery Capacity
EB300: 286Wh
Expandable capacity to 572Wh
EB600: 572Wh
Expandable capacity to 858Wh
RIVER 3 Plus Supported
UPS
<10 ms
Noise Volume
<30 dB
2 ports, 5V=2.4A, 12W max per port, total 24W
1 port, 5/9/12/15=3A max, 20V=5A max, 100W max
Car Output
AC Input
360W, 0-100% in 60 min
Solar Input
220W, 0-100% in as fast as 1.5 hr
Car Input
220W, 11~55V, 0-100% in 3.3 hr
Generator Input
360W. 0-100% in 60 min
Optimal Operating Temperature
20℃-30℃
Charge Temperature
0℃-45℃
Discharge Temperature
-10℃-45℃
Storage Temperature
-10°C-45°C
Footnote:
All the test results displayed on the page are based on our internal testing and are subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered conclusive evidence for all scenarios. Data was tested in a controlled laboratory environment, and actual user experience may vary.
3. The IP54 waterproof rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection.
Online 24 hours
