EcoFlow DELTA 2 Black (E980) Solar Generator – 980Wh, Fast Charge | EcoFlow NG – EcoFlow Nigeria
EcoFlow Nigeria
₦430,000.00 NGN
Hot
Hot
Regular price ₦430,000.00 NGN
Sale price ₦430,000.00 NGN Regular price ₦655,400.00
Save ₦225,400.00
  • 980 Wh cost-effective battery
  • <30 ms auto-switch for uninterrupted power
  • 13 output ports for multiple appliances
  • 3 ways to charge, 0-100% in 2 hr
  • LiFePO4 battery for 10 years use
  • Lightweight and easy-to-use
₦1,243,199 NGN ₦1,705,759 NGN
2kWh-6kWh Capacity |2400W Output |LFP |30dB
₦430,000 NGN ₦655,400 -₦225,400
Tired of Frequent Power Outages Disrupting Your Life?
Frequent power outages can be a nightmare, disrupting your routine by plunging you into darkness. Cooking, working, and even relaxing become extremely inconvenient. They strike at the worst times, leaving you feeling frustrated and helpless.
What You Truly Need is a Reliable Backup Power That Ensuires Long-lasting Backup.
980Wh capacity ensures all day backup
<30 ms uninterrupted power
10 years LiFePO4 battery
Fast AC Charge: 0-100% in 2 hr
Stay charged with solar power in outages
13 ports to keep all your devices charged
₦642,292
₦655,400
980Wh Capacity, Backup Your Essentials for a Full Day
Keeps daily life on track through power outages
With a 980Wh capacity, the EcoFlow E980 Portable Power Stationpowers your daily appliances for hours or even days, ensuring temperature control, communication, work, and food storage. Its 500W rated output can handle up to 650Wrated heating appliandces with EcoFlow's cutting-edge X-Boost technology, covering even higher backup needs to keep you comfortable during power outages.
Runtime of your essential devices
Everyday Solution
Remote working solution
Seamless Transition in Under 30 ms
No power interruptions for important appliances
Sudden power outages can disrupt critical appliances, leading to blackouts, food spoilage, or data loss. By connecting your devices to the EcoFlow E980 and linking it to the grid, it automatically switches to battery power within 30ms during an outage, a transition you won't even notice. This seamless switch ensures continuous power supply to your light, fridge, TV, and security camera, even when you're not at home or asleep.
LiFePO4 Battery, Built to Provide Long-lasting Support
3 ways to charge, from 0 to 100% in just 2 hr
Easily handle long-lasting, high frequency power outage
EcoFlow DELTA 2 Black (E980) Portable Power Station can be charged using an AC cutlet, solar panel, or DC charger. With a full AC charge achievable in just 2 hours, it enstures quick top-ups before the next power outage without damaging the battery.
13 Output Ports for Multiple Appliances
Charge all your home's appliances simultaneously
DELTA 2 Black (E980) Portable Power Station features 13 output ports, providing reliable
charging for a wide range of household devices to meet thepower needs of your entire family.
Lightweight and Portable
Power anytime, anywhere you need it
With 2 built-in handles and a compact design, easily move DELTA 2 Black (E980) Portable Power Station from room to room to handle urgent household needs. It's also portable enough to take outside for recreation activities or to support work, making it a highly versatile and flexible energy solution.
Simple, Smart, and Easy to Use
Easy enough for all to use
The EcoFlow DELTA 2 Black (E980) Portable Power Station is plug-and-play—no electrical knowledge or installation required. It works just like a standard home power outlet. A screen displays real-time power usage, so you can monitor and adjust as needed. For a more personalized experience, why not use the EcoFlow app to get more smart control.
Download the EcoFlow APP
980 Wh
Extra Battery
Please note: This device is not compatible with the DELTA 2 Smart Extra Battery
4 ports, rated power 500W, X-Boost up 650W
650W
4 ports, including 2 x 18W each, 2 x 12W each
2 ports, 100W
Car Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max each
AC Recharge
0 - 100% in 2 hr
Solar Recharge
11-60V, 15A, 500W max, 0-100% in 2.9 hr
Car Charging
Support 12V/24V battery, 8A, 96W Max, 0-100% in 11 hr
LFP (LiFePO4 battery)
Connectivity
Wi-Fi & Bluetooth
13 kg
2 year
What are the advantages of the DELTA 2 Black (E980) compared to a fuel generator?
The E980 is eco-friendly with zero emissions, operates quietly, has no maintenance costs, provides instant power without waiting for startup, and saves money on fuel expenses. It can be used in the house without noise and exhaust fumes.
What are the advantages of the DELTA 2 Black (E980) compared to lead-acid batteries?
Compared to lead-acid batteries, the E980 stands out with lighter LFP battery packs, longer lifespan and lower cost. While lead-acid batteries typically Iast only 300-500cycles, the E980 delivers 3000+ cycles - that's a 6-10 times longer lifespan. E980 can charge faster than lead-acid batteries and has advanced safety features to prevent overcharging and short circuits.
How can I maintain the battery to extend its lifespan?
The E980 features a Battery Management System (BMS) that inherently extends its lifespan compared to similar products. To further maximize the batttery's longevity, it is important to regularly charge it to prevent deep discharge, avoid exposing it to extreme temperatures. Users can protect the battery by flexibility setting lower charging speed, the charge limit to 80% and the discharge limit to 20% via the app. Additionally, periodically inspect the battery for any damage and ensure all connections are secure.
Is the DELTA 2 Black (E980) suitable for outdoor activities?
The E980 is designed to be perfect for outdoor activities. Its lightweight and portable design make it easy to carry, while its support for car charging adds to its convenience. The E980 is also built to be durable and withstand rugged conditions, making it a versatile and cost-effective solution for indoor or outdoor scenarios.
